Configures the auto-peering TCP MD5 password devices will configure in the TCP MD5.
| auto-peering | Specifies Auto-peering. |
| one-config | Specifies changing the BGP Auto-peering OneConfig configuration. |
| password | Configures the password for Auto peering neighbors. |
| none | Removes the current password |
| encrypted | Specifies that the password is in encrypted format. |
| tcpPassword | Specifes the TCP MD5 password/secret-key. |
N/A.
Changing auto peering password might cause peers to be disconnected if passwords do not match.
The following example sets the password to "123":
# configure auto-peering one-config password 123
This command was first available in ExtremeXOS 31.1.
